Re: mercruiser 4.3 1-84r 19" prop over reving 5000-5500rpm
Definately need a prop change. I have a 4.3L with 1.81 Ratio, When I had a 14.25x21P 3 Blade Alum prop on there I couldn't get to full throttle without smacking the Rev Limiter, switched a to a High 5 21p and got the same results. Switched to a 23p 3 blade Alum and got the RPMs in check and picked up speed, going to trying out a 21p 4 Blade SS prop this weekend to see if I can keep the RPM's in check and get some additional bite, if it doesn't work I'm going to try a 23P High 5.
Try a 23p Alum and see if that brings you into your RPM Range and then you can start dialing in after that...
