I have a ’03 bayliner, with a 3.5L? (135HP) 4 cylinder merc I/O. I just got it out the garage last weekend and got it ready for the water. I put new gas in, hooked up the water muffs and tried to start it. Nothing, so I put the battery on the charger, and left it for a few hours. The indicator never went pasted 75% charged, even after several hours. So I disconnected the charger, and connected it back up. The motor turned over and started. Turned it off and back on, started again. So I put the charger away and got the boat ready to take to the lake the next day. Next day I took it to the marina and just to make sure, made sure the motor would turn over. Nothing!, 2nd turn of the key produced a ‘click’. Ok, must be the battery.
The place I am putting my boat is a marina where I will be storing it during the summer and they wanted someone from the marina present when I brought the boat in. The guy was with me when I tried to start it, and he said it’s most likely the starter solenoid. They later called me saying the battery does not hold a charge and I need a new one, I assumed that. He also said I should change the solenoid also. I don’t trust mechanics I don’t know, particularly when the bill would be near $500.00!. I told him to just put a new battery in.
Why would he say I need a new solenoid if it did start for me when I had charged the battery? Now the wife is worried the boat won’t work. Should I worry? Also solenoids do not cost $250.00 to install. The battery installed alone is $200 ( which I expected). They guy said the motor wont always start, even with a new battery, which I never had an issue with starting before.
What would I notice if the solenoid was going bad, or do they just quit?
