I just finished connecting my new rebuilt motor. Its a 165 inline 6 with an alpha one gen1 housing and drive. I had a bunch of snags during the install because of I also upgraded the housing and inner transom plate, however finally was able to get her in. So heres the issues I am now faced with:
1. Tried to turn the key and nothing. It seems like the wiring on the starter is either wired wrong or I have a wire cut somewhere. Is there a way I can test the wiring? I was able to jump the starter to get her running. I wired the starter same way when I disconnected the blown motor.
2. Once running, I have a grinding noise from the back of the motor. It sounds like there is something hitting tin, almost as if the starter is getting hung up and not disengaging. I am not sure if this is possible, but my first step is to pull the starter. I have a brand new coupler installed, new gimbal bearing, new outdrive shaft and u-joints. The flywheel is original, but the flywheel cover is new since I needed to upgrade due to the mounts being different on the transom plate. Any ideas what this could be?
On a good note, the motor itself ran great with perfect compression and oil pressure.
