So. Purchased one 1974 Larson All American 186 Bow Rider with Mercruiser 302 and Merc 888 outdrive. Boat is exceptionally maintained, and in tip top condition. Dropped the lower portion of the outdrive to service the water impeller and housing. Used Mercrusier parts. Went to re-install the l/u and am unable to fully "engage" the portion again to the upper outdrive. Gear selector was in fwd when I lowered the l/u to perform service. I have since manually rotated the gear/range selector to neutral and the hand gearshift to neutral as well. What am I missing. Thank you in advance for your help.
