i pullled the drive apart to replace the impeller. there isa plastic sleeve that sits around the water intlet tube. this is in theupper section & above the sleeve that connects the waterpump housing to the tube. the sleeve is loose & does nothing from what I can tell
I am trying to add photos, lets see if it works.\
next thing is that there is no water pump face seal that they talk about. do I need this?
also, the manual talks about an aluminum dam that i cant figure out what they are talking about
Joining Drive Shaft Housing/Gear Housing
1. Lubricate the end of the water tube (in the drive shaft housing) and the splines of the
drive shaft with Quicksilver 2-4-C Marine Lubricant with Teflon.
NOTE: The aluminum dam has been changed to a rubber filler plug. If the aluminum water
pump dam in the gear housing has become corroded or damaged, it can be replaced with
the rubber filler plug.
IMPORTANT: Ensure that the drain hole of the aluminum water pump dam is not
clogged with any foreign material as damage may occur if it is.
71436
71436
