1984 Mariner 70hp outboard. I'm trying to figure out where the Trim Limit Switch wires should plug up. The previous owner had cut off all connections and plugs for the trim pump, so I don't know how to hook the limit switch up to it.
From the motor, on the left had side of one of the cylinders, there is the limit switch. It has two wires coming from it; a white one and a black on. At the trim pump, the PO had cut off the harness so I have a blue wire, a green wire, and a purple wire connected directly to the solenoids/power pole. These wires run up to my trim switch at the helm.
All of this works just fine. I simple need to figure out how to incorporate the trim limit switch into the fray.
