Re: 3.0 and 2.5 questions
Hi Fickett,........ Welcome to the forums here at iboats.com.......<br /><br />Where abouts in the land of Maineiacs are you hailing from,.??...<br />I was born,+ raised in Old Town.......<br />
i was wondering if it is possible to put a 2.5 in it's place
Ayuh,..... That's Possible....Complete Engines anyway,.. The Blocks are Not the Exact Same, Internally........Externally they Are the Same.......<br />The only Visual Difference I know of is;<br />The 3.0l has a Harmonic Balancer mounted to the front of the Crankshaft,.. The 2.5l has Only a Pulley.......<br />
also does any one know what years the 3.0 stayed with a 2 piece rear seal
I'm Not Sure of the Years,....<br />But,.....<br />The Differences Are Adaptable using a Retrofit Coupler.........Sierra makes such an adapter coupler.......<br />
that the 3.0 had different head designs in it's time so i am not even sure if my head will fit on the 1994 block.
Ayuh,.... There's Alot More different Heads than most of the fellows here even Know About,......<br />They'll All interchange,... Just some Flow better than others..........<br />BTW,..... Your 85 head is 1 of the Better heads..... <br /><br />I've got this 1 sitting on My shop floor,+ It's Looking for a New Home........<br />It's out of an 84 boat,+ was running Great with removed,....<br /><br />
<br />
<br /> <br />I'd love to let it go for about 1/2 the # that Dave says a New Long Block goes for.......<br />'Course,..... This is a Complete Plug & Play crate motor........
