Need help to identify '84(?) 9.9HP Gamefisher
jim j geezer
I thought this'd be a snap. Just write down the model & serial numbers and search SearsPartsDirect. Found it too.
Sort of...
Search result
Just to explore a bit, I clicked on and expanded the parts view for the "ignition" parts.
Imagine my surprise when I learned that my 2-cylinder outboard uses just ONE spark plug and ignition coil!
I'm guessing this is a Force from '84. Can anyone confirm or re-direct?
Thanks.
M
mrcrabs
Guest
Re: Need help to identify '84(?) 9.9HP Gamefisher
I would put it at minimum 86-88, what your looking in the diagram is one side of the BIM coil setup,
do a search here on this forum for 'Standard Magnito"
jim j geezer
OOOOooooooooooo...
NICE source!
Thanks. :)
jim j geezer
Thanks guys.
Now I gotta search for a couple of USED parts:
1. A 15HP carb, part# F7150611 (FO-1B)
2. An aluminum prop
"USED" because I'm grappling with a sharply-limited fixed income.
Let fly with tour favorite used parts sources.
BTW, I did a search for "standard magnito" and drew blanks.
Wot's a "BIM coil setup"?
SeaKaye12
Well; there's the list of salvage yards that is in the sticky:
http://forums.iboats.com/showthread.php?t=438822
You apparently have the part numbers so that makes e-bay searches easier. If you haven't already done so I would ask over on the Chrysler/Force forum here.
Are you attempting to convert your 9.9 to a 15? I would read about that if you haven't already. Sometimes depending on the engine it can screw up your idle quality somewhat.
If the budget is tight I would postpone that anyway; you might not see all that much difference and it will stress the engine due to the higher RPM's...
Sounds like fun though :)
Chuck
PS: "Standard Magneto"= http://www.standardmagneto.com/
It's a company that sells ignition parts .
BIM Coil= http://www.google.com/search?hl=en&...0.0.0.2.240.1945.6j7j3.16.0...0.0.BaLrvMGzkRk
M
mrcrabs
Guest
Just to keep crabby happy.
There are two ways of getting on my bad side, boys: I don't like kids playing in my yard, and nobody but me touches me thermostat.
---Eugene H. Krabs
