revincamaro
- Jun 12, 2012
- 2
I have a 2007 Stingray 22' with a 5.0 Volvo Penta I/O. While working on the throttle unit, the trim ran to the full down position and stopped. Now the trim button on the throttle does not activate the trim pump, nor does the trim switch on the stern. Two questions: I was told there is a heavy fuse between the starter solenoid and the trim pump that may have blown or that a 10 amp fuse may be blown. I cannot locate either fuse so I would appreciate if someone could tell me where to look.
2nd question: I need to move the boat but can't due to the outdrive being in the full down position. Is there a way I can bypass the switches with a jumper from the battery? If so, how, as the trim pump on this model is on the outside of the transom on the outdrive mount.
Thank you for any help.
