Had the boat out this week for first time in 6mos. (but started every 2 wks. or so) and the overheat buzzer went off and i shut it off instantly. Waited about 10 min. and fired up with no problems and buzzer never went off again. Didnt make any long runs but enough running for it to get hot. I've had this motor since new and all the up grades were made after about 40 hrs on it and now has over 500hrs. Question is it was peeing plenty of water but the temp of the water coming out was hot to the touch then seemed to get cooler then hot sorta back and forth. Pulled the original t-stats out and put yhem in a pan of hot water at the same time and one opened up about a minute before the other and the valve on the one that took longer to open looked lopp sided compared to the other. Am i on the right track with saying they should be replaced? Thanks!
