I have an OMC cobra outdrive that works fine when the engine is not running. When the engine is running, the trim automatically goes to the down position and the trim motor continuously runs. I replaced the solenoids and I thought it fixed the problem. Ran it all day and right at the end, the trim motor just started running. I have to disconnect the motor until I dock, turn off the engine, plug it back in and then I can raise the outdrive. Any ideas what to check?
