houstonnoob
- May 5, 2012
- 50
Can someone identify this picture below with the red arrow point at it and its purpose? It also appears the tip of it is clog up.
Remove the tube from the speedometer and blow it out.
Do NOT leave it unhooked, at 35mph it will make a fine super soaker and you will soon know if your bilge pump is working properly.
Edit: By "Clogged" do you mean you can see dirt in it?
Or, do you mean you can not blow into it? (Which you should NOT be able to!)
If it looks intentional, it may be that someone plugged it because the tube to the speedometer was leaking water and they did not want to fix it.The speedometer system should be open at the pitot end and nowhere else.
If you can pressurize the pitot end of the tubing to check for leaks ...
2 psi = 17 mph (Typical pressure produced by a set of health lungs.)
6 psi = 30 mph
11 psi = 40 mph
90 psi = 116 mph and Damaged Speedometer and Hoses!
Do you not have a bilge pump? I think it would either be punping or it isnt working. What about when you take the bildge plug out after you pull the boat out with the trailer. How much water are you seeing?
Actually an air pressure gauge. Water compresses the airThe speedometer is really just a water pressure gauge with the face calibrated in mph instead of psi
