Lower Rear Pan for 1965 Johnson Meteor II 90 same as 1966 Johnson Golden Meteor 100
jb93
Lower rear pan on my 66 Golden Meteor 100 is cracked (engine model V4ML-12R). I found one for a 65 Meteor II 90 (engine model V4ML-11). Will it fit my 66 100hp? Looks like it, but want to make sure bolt holes line up. It is for sale out of town, so I can't measure it and seller makes it my responsibility to make sure I know it will fit. I have a parts list on my motor, but the parts lists for the 65 Meteor II 90 is not downloaded on the marineengine.com site. Thanks.View attachment 151957
63Sport16
Re: Lower Rear Pan for 1965 Johnson Meteor II 90 same as 1966 Johnson Golden Meteor 1
Not the same. The 90hp rear is rounded, where as yours has the indented contour shape.
jimmbo
The evinrude pan is rounded and is the same for the 1964-65 90hp and 66 -68 100hp
The Johnson pan has the indents and again stays the same as above except for it fit the Johnsons
jb93
The V4ML-11 is a Johnson 1965 Meteor II 90hp. The V4ML-12 that I have is also a Johnson but 1966 Golden Meteor 100.
From the replies above, it sounds like it will fit but the Evinrude version won't. I just can't quite tell from the way the replies are
worded...does it fit or not? Thanks again
jimmbo
it will fit a 1964 thru 1968 90hp or 100. indented is johnson. rounded is Evinrude
jb93
Cool. Thanks.
