Re: Raise Trailer Bunks With the Boat on Them?
Regarding the current height. The boat is setup this way intentionally. Because of the size and weight it takes more water to float it off the trailer. If you raise it, there is a strong possibility that you'll end up with the launch vehicle in the water before the boat is able float off. Powering off may even be difficult.
I have two boats setup for low level launching. One is a jet and the other an outboard. I have to raise the motor on the outboard just to get the hitch on the ball and I have to run a transom saver because I am well past the trim when I raise it to a safe level. On the Jet, I have a guard built into the trailer with a roller on the bottom. Sort of like a wheelie bar. Boy do I love it though when I have to launch from the beach or on a lake with low water. I'm in and the rest of the guys are standing around trying to figure out what to do. There are trade offs certainly but in my case, they're worth it.
If you are set on raising it then I highly recommend converting to rollers. That will get you back some of your launch ability. I could have gone roller on mine too but I had the materials and I'm a welder so it was just easier.
