I need to repair the block .
I am hoping to use HTC 2000 .
The block is warn on the outside of the water way in 2 areas on the side that the cylinder head attaches to.
and a small 2ml deep grove on the exhaust side of the block,this is going from the exhaust to water way.Would a
filler do the job on this or use HTC 2000 here also?
I have removed the power head from the upper leg of the outboard and was wonder if there is anything else worth
doing since its removed and mostly stripped down.
regards
regards
