oil blowing out of my dip stick
echobrent
I have a 1969 mercruser 120 that is blowing oil out of my dip stick.<br />May not be the origional motor, but I got the boat for almost free.<br /><br />Any ideas????
Weirdwalt
Re: oil blowing out of my dip stick
Excessive blow by. Now you know why it was (almost) free.
Haut Medoc
Welcome to iboats! :) Walt is just plain mean.....Probably right, but plain mean ;) You need to do a compression test & see what the numbers say.......Any exhaust coming out of the oil filler on the rocker covers or weird noises?....Again: compression check.....JK
ziggy
HM, what does exhaust coming out of the oil filler on the rocker covers indicate?
Haut Medoc
Hole in piston from detonation.....You will hear it, too.....A little steam /smoke is not uncommon, though.....A compression test will tell that....Because it will be 0 #'s.. ;) ...JK
Capt Ken
Bear with Walt, the wife probably cut him off again and he's getting a bit edgy.
ziggy
thanks HM, was just curious.....
paulie0735
You might like to check that the inlet manifold is supplying a 'strong' vacuum level at idle to the PVC valve in the rocker cover. If the engine is not venting the negative compression buildup in the crankcase correctly than it will vent it out the dip stick tube along with the oil.
That's Great,..............<br /><br />Now all you have to do is,........<br /><br />Rebuild the Motor,.......... Or,.. Replace It.......
Weirdwalt
Ya'll have to excuse Ken he's gettin edgy because the thermometer in his back yard has been in the 40's lately. He's gettin ready to call FEMA and head for his emergency shelter. Why just imagine, water might actually freeze!
paulie0735
Yeah, great advise that! You could rebuild the engine or even replace it.............. Or you can check the vacuum port in the inlet manifold and make sure it not just blocked up (35 years of sucking oil fumes down its neck will do that). Also check that the PVC valve is working as it should and that the vacuum line is in good condition and not cracked.<br /> I’m not saying your engine does not need a rebuild, just worth checking a few simple things first.<br /><br />I wonder how many engines have been rebuilt just because they seem to need it!!!!
rodbolt
I dont think that engine used a PCV system but its posible the breather clogged, a leak down test will tell you anything you wish to know about the cylinders sealing ability.<br /> if this is a saltwater motor rebuilding may not be worth it due to internal corrosion.
Jilly - 5
You don't indicate whether "solid" oil is coming out, or if oil is "spitting" out, or if it's foaming out. Also, what oil pressure gauge readings are you getting? Also, does your engine have your oil in it, or unknown oil from a previous owner? If your oil, what is it? I agree, start simple with a more thorough look at symptoms and facts first.
tony_56
Another good way to tell is start it and pull the dip stick and put your finger over it, it will tell you alot also, if it sukc and pushs, then you have very serious internal problems but if it only pushes then it might possible only be the pcv like rodbolt said, i know my honda had a pvc, dont know for yours though, you should look it up
DTSonnax1
The problem is poor crankcase ventilation.Check the vacum ports on the base of the carb/injecter body. :cool:
King P.V.
Just what exactly are the problems associated with the engine?? Is it hard to start?, won't idle? no power? .............
KRS
Banned
Echo welcome! Good news about the boat, not so good about the engine. This however, is the perfect time to start learning about your engine.<br /><br />Read the posts from Haut, Bondo, and Rodbolt, lots of experience in this forum.<br /><br />Good luck, and remember to post an update as you work along. PS.... if you have a picture, post it.
