engine question
wes302
What engines are compatible with the 275 outdrive? I have the aq 131 and it runs great just looking for a little more....
captmello
Re: engine question
your outdrive is geared for the four cylinder engine. A bigger engine would require a lower unit with the correct gear ratio. A complete drivetrain swap from a donor boat is usually the cheapest way to go.
