starwriter
Banned
- Jun 3, 2012
- 42
I have a 1991 Welcraft 186 4.3 L Mercruiser Alpha 1 that I restored and ready to try it out.
On the Throutle handle there is a switch for trim up & down.Below that is a button says trailor.
What is the trailor button for?
When I first got this boat.I noticed that the trim down button wasn't working.Only the up trim button was.To bring the trim down I had to use the trailor button.As the trailor button brings the trim down.
I took the boat out the other day and noticed the trim up & down button is working now.Don't know if the trim switch has a short or not but,now it seems to work.
What is the trailor button for?When I push the trailor button it brings the trim down.
Seem's theres two down buttons for the trim?One on the throutle Handle and another is the trailor button.
I don't understand why there is 2 different buttons to bring the trim down?
The button says trailor.I can't see why you would push the trailor button on for the trailor?If I do that the prop will hit the ground while on the trailor.When loading the boat on to the trailor.I raise the trim up because,of shallow water.
I have a trim up & down trigger button.Why trailor button?
I have another question on this same topic please,
I am a newby with boating.What is the trim up & down trigger button for?I know it brings the front of the boat up & down.And also,to avoid sand barges & shallow waters & loading & unloading from trailor.Is it for speed also?
