ilovepepper1
- Jun 11, 2012
- 2
I have a 2007 Chaparral Sunesta with a Volvo Penta 5.7 GI. When I turn the wheel in either direction I'm hearing a clicking noise that sounds like its coming from the lower unit. Any suggestions?
The clicking sound "could" be your U-joints because the needle bearings are starting to go.
This is just a guess mind you.
Does your steering wheel jerk/throb as your applying it in either direction? is your power steering resevour topped up.
Is your power steering belt loose, more 1/2 inch deflection in the center is loose and could be slipping as your applying preasure to the pump while steering.
