Dabbler_E
- Apr 20, 2009
- 338
Just bought a '71 25hp sportster for $80, has sat for years. Tested compression and got zero on both cyls, before realizing that the PO had removed most (but not the bottom 2) of the cylinder head bolts. I put them back in and lightly torqued (I know there's a very specific torquing sequence -- awaiting factory manual), and got similar compression (95-100 psi) on both cyls.
My question is: do I need to put on a new head gasket, or should I just torque per specs and make sure compression is good?
For those interested, there is strong spark on 1 cyl and weak/intermittent on the other, so a point/condenser tune up is in order. Prop is in not bad shape. If I can resurrect this motor cheaply I will do a happy dance.
Thanks!
Thanks!
