Have a 1996 Bayliner 1950 with 3.0 L Mercuriser. In storage for two years, had fully winterized it. Took out on water, ran fine, drove for hour and turned engine off. When I went to re start, it would ony run at high RPM (over 1500). Towed in, rebuilt carbs fully, took every piece apart and soaked in carb cleaner. This was late in the season last year. Re-winterized lst fall, and stored. This spring I started up in driveway with muffs, started easily, idled just fine. Took out on water, ran fine on idle out of harbor, ran speed up, engine stumbled, came back up to speed and then died. Again would not run at idle but would run at high RPM. Gas is two to three years old. I am stumped as to what is causing this problem. Any ideas on what to do next, what to check and in what order?
Thanks
Thanks
