Scotchman
scotchman
I have 1978 mercury outboard 402 -40hp - it stops after running five minutes on the lake . ITS just like you cut the key off or some thing is getting hot. IT takes about thirty minutes to get it to started again. DOES any one know what i should do?
GA_Boater
Re: Scotchman
Open your tank vent. And use a post title that makes some sense will draw more responses.
