FishBM2012
- Jun 11, 2012
- 2
Hi
Need some help. I've got a 1993 70HP Evinrude that sounds an alarm running below 2000 RPMS. If I run the boat at 20 plus MPH the alarm doesn't sound. Is the beeping noise the overheat alarm? Water is flowing strong through the peep hole. The water is not hot coming out of the peep hole nor the lower unit. I can leave my hand there for as long as I want. Stream is constant. Could this be a thermostat issue? Thanks Ken
