propmonster
- Jun 11, 2012
- 16
Like the title says, the engine starts great, runs great at mid range and full throttle, but from an idle when I try to accelerate it will bog and die unless I bump the choke then it will take off and go great. Also if I try to go slow down the river (no wake speed) it sounds like it drops a cylinder on and off then acts like it loads up and wants to quit, but the odd thing is if again i bump the choke it will go. This is what I have done so far, rebuilt fuel pump, all new gas lines, cleaned tank, new bulb and hose and cleaned carbs very well. I need help! this makes it a big pain in the butt to pull skiers or run the river. Thanks for any in put.....
