Peteypablo25
- Apr 22, 2012
- 79
Hello IBOATS!
This is my first post. I've been searching these forumns for quite some time about different subjects and have answered just about all of them! So, first off, thank you to everyone who takes their time to share your knowledge!
OK, so I recently purchased a 1985 Bayliner Capri 19' Cuddy and so far everything is looking OK. It has a 1989 force 125 on it (I have model # but Im at work right now) and the spot where the serial goes (left side of motor when looking from back) on the transom mount is completely worn off...All I see is the word VOID. I live in RI where I have to register my outboard (dont need title, just register it) and the previous owner did not register the motor.
My questions are:Is there any way to cross reference a different number in the engine to find out the serial number of the engine itself?
Do I even need the correct serial number to give to the DEM to register this or can I take any number off the block and use it as the serial?
Again, this is for registration not insurance purposes so I am not sure if the DEM actually does a check to see if the serial is valid or not. I want to be legit about everything when I get out there so I would apreciate any input.
Has anyone ever made up a serial number to give for registration purposes and had (or not had) any issues?
And finally, can I "borrow" a serial number fom a parts motor to use on mine or would this cause any issues (bill of sale from Previous Owner etc.)
I have searched alredy and have only found out the location of where the number should be but, nothing about possible ways to get around this if it isn't present.
Thanks in advance!
Pete
Thanks in advance!
Pete
