Took the boat out last weekend, was having a total blast then I noticed the auto bilge pump kick on. Kind of wierd, never happened in the last 30 years we owned this boat, so took a look under the cover and water was pouring in. Beat feet for the boat ramp and got her out of the water. Couldnt find the source for the life of me, then I seen a small hose clamp worm screw on the bottome of the outdive (mid unit) where it attaches to the tansom. Pushed on it and sure enough the boot had come unseated. Good enough, at least it's not a major problem. Brought it home, looking throuh my trusty service manual and it looks like you have to take the boot free from the transom to get to the back side and get to the worm screw on the big hose clamp. Before I do all there is there a way to re-secure it withough taking the screws out and breaking the seal on the tansom? If not, any pitfalls to look out for? In my mind I shoud just be able to pull all the screws, carefully seperate the boot from the transom, clean the old sealant off (any good ways to do this without damaging the boot), put new sealant on and run the screws back in, any problems with that plan?
Also, what kind of sealant do I need to use between the boot and the transom?
Thanks for the help!
Boat is a 1976 Cobalt 18 foot bowrider with OMC electishift stinger drive
