screeminreelz
- Jun 6, 2012
- 10
I took my boat out this morning and the motor idled and shifted into gear now (it didn't until I cleaned the carb) but when it is just about to go on plane, the motor boggs way down and i don't have any high-end, just low and mid. I re-did the fuel pump and cleaned the carb and replaced the float. The float looks different though, it is all plastic instead of the one with a metal plate on it.
Is this most likely a fuel issue or could it be something else? I suspect my timing isn't right because my dad messed with it. Thanks for the help, I'm in a little over my head...
