Water pump impeller replacement (What kit do I need?) 165 HP 1987
Jimshoe
I have the outdrive off and saw on this forum the "how to's" of replacing the impeller in the water pump. I need to know a good place to buy the needed parts for this repair, what are the needed parts and or part numbers and also if a kit is available. 165 HP 1987 Mercruiser Engine Serial # B648
Re: Water pump impeller replacement (What kit do I need?) 165 HP 1987
Ayuh,... You need the impeller Kit, for yer Alpha 1, from right here at iboats...
Click the Merc parts link above yer post...
