1978 Jonny 115 . I have cleaned and rebuilt the carbs, linked and synced, adjusted the timing and floats. It runs ok but I have the following symptoms. getting a large amount of fuel from the carbs when I choke. No fuel leaking when it's running though.
also getting fuel pouring from the lower carb after I shut the motor down.
Plugs are wet after running in the tank at various rpm below 2000.
Seems to load up and miss when idling.
I have the floats adjusted way past level as shown in the service manual so it should be running lean if anything.
Spark is blue and jumps a mile.
Could this be related to the Reed valves?
Thank you in advance....Bill
