Hi All.
I got the Mercruiser 470 kit but had to use a teddington water temp switch designed for the alarm system.
http://www.asap-supplies.com/marine/temperature-alarms/high-temperature-warning-switch-99-degrees
It has 3 contacts. Common, ground and ?
Looks like this -
It wont fit next to the existing sender due to space restriction.....
I cant find any installation guides anywhere. Can someone kindly tell me hot to fit or point me in the right dierection please ?
Where does the oil pressure switch go ?
Does the water temp switch replace the existing one ?
Do I need Tee's ?
Not quite sure where to go here. Any advice greatfully received.
Looks like this -
Do I need Tee's ?
