3.0 mercrusier interchange question
az28
Hello,
I have a Campion boat with a 3.0 mercrusier alpha one. I need to replace the engine due to cracked block.
What years or models of engine will be a direct fit?
Re: 3.0 mercrusier interchange question
Hello,
Ayuh,.... Donno,... What vintage are ya startin' with,..??
Basically, any 3.0l from the beginnin' to current production, can be adapted to run in whatever vintage ya start with...
The 2.5l marine motor is the only other easily adaptable replacement...
Btw,... Welcome Aboard,...
az28
thanks for the reply, it is a year 2000
Ayuh,... That's current production,.... '91, 'n up, should be plug, 'n play...
fishrdan
I'd definitely stick with 91 and up, the earlier engines have differences that will make it spendy to adapt, flywheel, coupler, rear mount.
az28
i'd definitely stick with 91 and up, the earlier engines have differences that will make it spendy to adapt, flywheel, coupler, rear mount.
thanks!!!
az28
If I buy a donor boat from 1990, how difficult would the swap be?
Ayuh,.... '91, 'n up is Better, but that's a possible to do swap...
considerin' you'd have All the pieces of both to start...
