We have a 1974 Drifter with a 215 Mericruiser inboard. It starts a runs in neutral with no problems. Every time you put it into gear, forward or reverse, the engine dies. I was told there may be a problem with the neutral safety switch. If so does anyone a solution. Where is this switch located and where could I get a replacement if needed. Thank you
