Help starter
Jplask
305 5.0 in a 2005 bayliner was wondering the steps to take out starter and I also have a bit of a womp womp noise when idling, doesn't increase when given more throttle there's no shake or vibration I'm wondering if it could be the impeller?? Thanks for any help
Bt Doctur
Re: Help starter
Remove the + battery cable from the battery
Remove the battery cable and wirinbg from starter remembering what you took off from where
Remove 2 starter bolts, maybe a bracket, and remove starter
Never heard the "womp,womp sound" cant tell you what might cause it.
cr2k
Re: Help starter
New or rebuilt starter MUST be marine certified or you may go boom and kill your family. New bolts should be used every time you remove the starter.
