AirborneSRT
- Jun 7, 2012
- 10
Hello everyone, my name is Jonathan (John for short)
I've followed this site for a few months now and learned a lot and just decided to recently sign up, so kudos to everyone for all their great advice and knowledge as you've been a key part to my success with this motor.
Here it goes, in Feb this year I recently purchased a Larson Shark 18ft tri hull (forgot year, roughly around same as engine.)
and have been using it as my weekend/spare time project between surgeries and etc. Originally it had twin 40's I was told and one popped so the guy bought a 78 Evinrude 115 in non running condition, was told it needed carbs sync'd & linked and it's good to go...
Well here's june and I've flushed and refilled the gearcase, new seals all around for the lower unit with a new water pump, new spark plugs and being an ASE technician on automotives and being an auto enthusiast since pre-teen I checked the carbs and found them to be in great condition no tarnishing or bad seals, floats work good and all gaskets are tip top.
I've used fresh fuel and Pennzoil 50:1 mixing directions and I have come to some serious problems so far...
I took her out on the water and just could NOT get her above maybe 15-20MPH no matter what, she doesn't overheat but after maybe half-ish throttle she just doesn't go, it seems to slightly bog down... And she smokes, like a lot...
So looking further into it I notice on muffs ANYTHING above base idle and she pops and stutters and shakes...
So, I bust out my spark checker and ALL the packs fire GREAT, very bright blue strong spark and no intermittent sparking.
So I think wtf... Compression test, well I was very surprised and somewhat astonished... All cylinders have only 65PSI.
So I do one more test to see if maybe when the ignition components get warm they foul, so with the engine on muffs at idle I start pulling plug wires, starting on the left side of the engine (looking at them from the back standing in front of prop) each plug pulled on left side almost instantly nearly killed the engine until put back on.
Right side, absolutely no difference in idle at all, no different exhaust note, NOTHING AT ALL... I'm like wtf I just tested the spark! So I grab my spark tester, and both plugs are still firing perfectly. I took both plugs off the right side of engine and nothing happened, no idle change, no different exhaust note, nothing...
Now I know 65PSI is seriously freaking low, like how the hell is it still working low... But I'm trying to put off the whole head work until after summer because we wanna do some fishing and cruising on the water. I don't need to do 60MPH or anything but 15 was just almost not bearable...
My question is why is the WHOLE RIGHT SIDE not firing?! Head gasket? Piston rings? I looked all around the gasket and noticed no seeping of fuel or oil and no damp spots at all, all dry and all still the same silver paint color of the engine telling me the gaskets are hella old... So what could cause that? I'm beyond stumped, I have the same cylinder pressure as the left side of the engine, same spark, and the cylinders absolutely get fuel because it spat at my face when I turned it over... What am I missing?
