Re: how easy is it to instal a starter?
A 6HP motor would not have room under the cowl to accomodate a starter....not to mention the cost of motor, switches, relay, wiring, battery, etc. required to make a starter work. Is pull-starting a problem for you? Most motors up to the 15HP range are manual start.
Good Luck!
