I believe I I targeted my leak and it's not the tank but the connection to the hoses.. But my question is it looks like its coming from between the plastic of the tank and the metal fitting? I will replace hoses and put new plumber tape on all the threads but is there supposed to be a seal between the plastic and the metal fitting?
Also I should state its a 15 gallon permanent gas tank with vents and two metal fittings in the back. One for each motor...
