drukkentech
- Oct 31, 2010
- 3
I've done a bit of troubleshooting already and I am at a loss.
Stats:
1996 Bayliner 20ft
Mercruiser 350 V8 and Alpha Gen II Outdrive
I have hard steering whether the engine is on or off going left and right. The problem has been around for as long as I've owned the boat (2 years) and I finally started tackling the problem this season.
Troubleshooting steps:
I've replaced everything that I could think was faulty and still have tough steering. Does anyone have any ideas? The pump still doesn't make any noise when the engine is running (although the pump is brand new now). A boating buddy suggested that the steering cable can still bind when under load but be smooth when it's free. Does this make sense?
Any help is greatly appreciated!
-Evan
Stats:
1996 Bayliner 20ft
- I disconnected the steering cable from the power steering ram and i can then turn the steering wheel super smooth and easy left and right, lock to lock.
- I disconnected the outdrive from the power steering ram and can move the outdrive freely at the back of the boat with my hand.
- I replaced the power steering pump as it was making no noise and had no indication of it working. When I disassembled the power steering pump, i found that the pressure relief valve was stuck open. Upon installing a new pump, the problem did not fix itself.
- I then replaced the power steering ram/control valve assembly thinking that this was the only remaining culprit. After spinning wheel back and forth a number of times to bleed the system, the steering is still tough left and right. All of this testing has been done in my driveway with muffs hooked up, I have not actually taken it to the lake to test the new ram.
-Evan
