I just bought the boat yesterday. Of course never had a problem with it until now per the prior owner and I believe him. I went to start the motor at the ramp and put it down with the trim. Turned the key on, spun over about 5 seconds and quit. Nothing. No tilt, nothing.
Checked the battery for good connection. Eliminated the battery cut out. Nothing. Pulled the cover and found the top fuse, 20 amp, blown. Replaced with spare. Tilt and trim worked from motor. Went back up in the boat and everything appeared to be OK. Turned the key and POP. 20 amp fuse blown again. Checked the fuses in the console. 20 amp main there also popped. Just my luck.
Went out tonight and only hooked up the wiring to the console. All lighting and accessories worked with fuse replaced in console. Replaced fuse in motor. Tilt and trim worked. Turned key on and Pop. Console fuse and motor fuse blown again. Did a little head scratching before the rain ran me off and I think something is shorted somewhere back at the motor. I have seen the 30 amp fuse blow at the motor when the rectifier is bad. Never seen the 20 amp fuse blow when the key is turned on. Any ideas where to start. Boat has 150 hours on motor. Clean as a whistle. Previous owner out in it Friday. Ran fine.
