motor install on bracket
mausili
when installing motor on armstrong bracket do u raise the motor as it goes away from transom or leave ventilation plate even with bottom of boat, and is the motor set when trimmed all the way down parellel with transom angle or perpendicular with ground.
boobie
Re: motor install on bracket
You may want to post this in another section of this forum. Probably get better answers.
Chris1956
Boats with a setback bracket or jackplate allow the motor to be raised more. Unfortunately Trial and Error is usually how it is done.
