dove creek val
- Jun 2, 2012
- 10
1989 5.7 350cid mercruiser s/n oc606793 . No Points in cap.
Recently bought a 23' carver, ran good for 3 runs then started running rough at ldle- in fact wouldn't sometimes. Hard to start, in fact took out starter (bendix gear stripped) and broke tooth off ringgear- Pull engine.
Haven't adjusted anything. Could it be the timing advance mechanism stuck in the wot position changing the timing at idle? Cap inside looks dry. Should I be able to move/rotate distributor rotor back and forth a bit (with engine off) indicating mechanism is operating properly? Or does anyone know how to check for proper timing advance operation?
I am going the right direction or could it be hydraulicing a bit from an exhust jacket leak? Just in the process of pulling engine. Thanks!!
