ksmith3846
- May 11, 2012
- 7
I have a 93 200hp v6 that runs good idles fine gets up and goes but starts to bog at 3/4 throttle and will not go any faster i could tell it was fuel starved because i would start the engine put in gear and go and it would go up to 4600 rpm until it started to become starved for fuel. then it would go down to around 3000 rpms and run their. i tried cleaning the carbs but they were pretty clean,i checked both the fuel water separator and inline filter and everything seems to be ok and i checked the filter on the engine and it was ok. what else should i look for. I know it is fuel because it runs perfect until you try to go full throttle. the fuel lines from the tank to engine, inline filter water sep are all brand new. any help would be appreciated thanks.
