mistertwister87
- Aug 10, 2011
- 32
I have a courtesy light in the bow panel on a switch. The power for this comes from the fuse panel. Since I only have limited tab terminals on my fuse panel, I am using one of these. On this piggyback terminal I have the Nav lights and the courtesy light. So in essence they are both on the same fuse panel terminal (4Amp). Now I want to install a livewell light with a on/off switch in the same bow panel. Can I "tap into" the existing constant power run I made for the courtesy light to power my livewell light? Also can I use the same ground on the voltage gauge that is in the bow panel as well?
Thank you
Thank you
