I have brackets L shaped out of aluminum meant to be used at the transom attachment point plus the SS struts from the edge of the platform to the transom. BUT this wooden platform will sit a distance from the transom due to the transom shape, about 5" at the furthest point left and right on the platform. The existing L shape is 4" where it attaches to the platform. They were made for a transom that is straight, whereas my boat has a slight V shape to the transom. I think the transom attachment is a 12 degree more than 90 deg angle.
My question is this-
Can I modify the existing L brackets by attaching a length of heavy gauge aluminum where the platform will sit therefore lengthening them or how difficult would it be to make up a new bracket out of bar stock to the exact dimensions that I need? I have never worked with stock aluminum before.
I am not sure if there is a minimum length for the bracket on the transom side and on the platform side for my 17" x 74" teak platform>? I have seen the triangular shaped brackets in 6x12 and 7x14" so what is the recommended size for my 17x74 platform?
If I had to buy the triangle bracket I would buy the 7x14 ones I think.
Thanks.
Joe
Thanks.
Joe
