I picked up A 1986 ebbtide 166 bassboat with an 89 johnson 110 v4 vro. this is my first boat, and it seemed like an amazing deal. i take it to the water, get it started and let it warm up. First off theres water only spitting out of the back, not a steady stream. so im sure i need a water pump. but then as im attempting to clean it out and try to open it up thinking it might be alright, it has barely any power. would only get to 3k rpm or so. i had it out for about 5 minutes running all together and loaded it up as fast as i could. when i attempted full throttle, it also started knocking, but it didnt sound like a rod knock. it wont do it at idle, only when the engines under a load. i brought it home and checked the plugs, they were all in decent shape except they were coated with oil pretty heavily. i did a compression check and i got 105 100 and 2 90s. any opinions with this limited info? i had my temp gun on me i never let the motor get over 190 also. thanks for your help!
