Sorry guys you probably get a million of these questions. I have been premixing my gas in my what I believe to be a 89 year Johnson 90 horse outboard and last trip out the low oil indication beep was going off. Knowing that i had been premixing my gas correctly I decided to try and disconnect the signal horn/beep. Well I dug into it today and found four wires connected separately at base of where my key is inserted. From what i could tell this was the source of the beep so I began removing the wires and turning the key on/off until i found the source of the beep. I then disconnected the other three thinking they where the other three indicators, oil, temp ect. So i get it put back together and it wont turn over. What are those wires and would anyone know which order they go back on? I really screwed up here. :facepalm:
thank you all
thank you all
