udm328is
- Jun 6, 2010
- 126
Get one issue fixed and on to a new one, but I guess that is what you get when you buy an $800 boat that you no nothing of the history on it. I just started it up with the muffs on it after getting the timing set and a few other things. I have a 92 mercruiser 5.0 with a Alpha One Gen 2 outdrive, outdrive SN# is 00668470. I went to take the hose off of it and noticed the putty colored goop slightly thicker than pancake batter coming out from behind the drive, looks like from somewhere between the two rubber boots. Last week I changed the gear oil and used the greenish blue high performance one, got a grease gun and greased the three nipples on the drive. I have a feeling this is something obvious but being fairly new to working on boats, especially outdrives, I am not sure where to start. Thanks as always in advance for any and all thoughts and replied on this issue...
Eric
Eric
