Re: Stalls on acceleration
Thanks for the replies. The only reason I did the oil pressure switch is that it was suggested to me on here that if it was bad it could cut off the fuel pump. Also keep in mind that I am a learn as you go Google/iBoats mechanic so not always on the mark with understanding everything, but I am getting there. I went back out just now and re set my timing, seems I was off a bit, think I might not have tightened the screw down tight enough on the distributor. I also happen to notice that the fuel line right into the carb was dripping fuel ever so slightly and I tightened it and it seems not to be leaking. I fired her up and so far in neutral I had her running steady at 2500 to 3000 rpm's and she did not cut out on me like before. I have not tried in gear yet, crossing fingers. Just bought the boat last month from a guy that I am certain knew a whole lot less that I do about boats and boat maintanence if anything at all, so I am just doing my best to get her back into good working order without braking the bank too bad.
Thanks again,
Eric
