2000 Evinrude 225 E225FCXSS #G04856130
Recent history:
Just got my EMM back from DFI Tech. I was having the 3 lights error and they fixed it right up. The overheat sensor was causing it to not start/turn over (i.e. - dead). Put upgraded EMM back in and it ran great! (it also ran great before EMM sent off to DFI)
Today I ran about 30 miles just fine, then the motor shut off like someone turning key off. No warning lights either. Boat equipped with twins, starboard motor runs fine, port is the issue. Ignition switch turned to run, fuel pump runs as it should, and when ignition turned to start, motor cranks with no problems. The motor seems to catch, but will not continue to run. It acts as if the key is being turned off, rather than hesitating and dying, etc.. If you give it throttle while trying to start, it will begin to rev for a nano second and then will shut right down. I checked all connections, fuses, battery connections and I can't find anything. There is plenty of voltage with 2 big, fresh batteries. It is getting fuel, the primer bulb is firm. Motor was running fine last year and all spring - moving along at 4000 rpm on both engines and port simply died.
- I just replaced plugs on both motors, gapped at .28, indexed properly
- Replaced fuel filters - no shavings or contaminants (including water) in fuel
- I have check all fuses in the power distribution panel
I am thinking a sensor is bad or giving wrong reading but would like to hear from y'all cause I am not that good with outboards. Someone suggested the power distribution panel. . . . . .
Help!
Recent history:
Help!
