115 inline 6 1978 help plzs
slash123
ok this things driving me nuts i bought it last year still dont have it working right i put in local shop they had it 2 months and didnt fix it so i thought i would take it on my own.the guy i bought from said all it needed was a stator turned out it needed stator triger and switch box,so i replaced them all compresion test was 120 on all cylenders awsome i gues anyways i also replaced the water pump whole thing .. almost new motor now huh....lol so i used the guide to set timing in the forums ..got it to what i think its correct .... got distrubter pully set where i think it correct not positive thats where i need help .... i shot with timing light looks like its running idle at 10 btdcif i rotate distubter back to reduce idle it gets to 2-4 but idel poorly and steam come out peehole afet runing about 5or 6 minuts leading to make me think timingsing off causing it to over heat .... is that possible? i took it to the lake it ran at wot about 6 mph not good but found the number 3 carb had no fuel in it the needle valve asembly was bent so it wouldnt let any fuel in ... fixed that today havent tested it yet but still steam .... any ideas would be greatly aappresated ...........:confused: o yea its merc
canoemang
Re: 115 inline 6 1978 help plzs
only steam coming out ?
slash123
only steam after it runs that long but till it get warmed up it produses water out peehole then turns to steam water blows out 2 squar wholes on the lower section to though but i dont feel itss enough. scared if u will.....
Faztbullet
Are you sure the distributor is put together correctly and economizer pin/spring is in correct position???? That could explain the low rpm and when it steams is this on earmuffs or in the water????
slash123
pretty surebut now u mention it i dono cant seem to find the diagram in my pdfmanul either hmmmmmm and its in a test tankabout 4 feet deep
Faztbullet
When it steams, take your hand and feel the side exhaust plate as it should be cool to the touch, if its hot you have a cooling problem..
slash123
ok ill do that tomorow after work but if my memerey servse me right i think it was pretty hot the whole engine was prtty hot but ill recheck it cant think of what could be the issue either i took it apart the other night to check for debre wasnt any flushed out the cooling system with water hose while lower unit was off too just incase somthing was lodged in stem still no good....baffles me
slash123
ok got out there today ran it about 800 rpms and for about 5 minutes it peed then started dribbleing little then started blowing steam and the exaust plate was preety dang hot.....
Chris1956
Steam is definately not good. You used the white plastic water tube extension to help you get the copper water tube into the waterpump outlet right? Your waterpump has the stainless steel wearplate with a new gasket on each side right? The impeller had the drive key installed right?
Idle timing specs may be off. The idle timing should be 4-6*BTDC when the carbs are just about to start opening. Max spark advance is 21* BTDC.
slash123
yep i used the tube yep plates was put in gaskets on both sides impeller has the key in i just dont under stand what could be wrong driving me nuts ........
Chris1956
OK, drop the gearcase and put a hose on the water tube. Apply a little water pressure (the inlines have no more than 5PSI) and see if you get flow. If the hose just pops off and you get no flow, maybe something is clogged. Splines on crank and driveshaft are good? Driveshaft is turning?
slash123
ok ill try that yes drive is good yep drive tuns fine it has a 1/4 plug in the cylender cover i took it out and apply water hose to it with lower unit off i had water out peehole and water steem the other day though thats why in baffled so much
Chris1956
Well if all else fails, blame it on the waterpump base warping. It does happen. Buy a whole new pump base and cover and reassemble....
The water intake holes are clean as is the water passage under the waterpump? My Mercruiser would get that area full of barnacles and the motor would overheat....
slash123
ok loading up the vid failed comp crashed was down till 3 minutes ago but in all this time i took the cylender cover off droped lower unit took water hose conected it to the copper tube found that it wasnt going into the exasust plate like supposed to ive come to conclusion there is forieng matter lodged in the bottom of the block some where before the first journal that leads to the cylender cover area how do i get it un cloged
