Re: sensor
Do you see a wiring diagram on the motor showing the colors of wires and listing their functions?? If so, look at the head on the back of the motor and I feel you will see a sensor threaded into the head or close into the block. You should see the color of wire indicated on the chart connected to the sensor. Attached is my 35 HP Chrysler showing both the chart and sensor toward the bottom of the head.
Hopefully a 140 owner or a Pro will verify this info or correct it soon.
Good Luck! Please reply your find or more needed info back that will assist others and me.
